I'm trying to set the intf parameters for S-Port0 as follows:
intfParams.resetGpio = 0xFF;
intfParams.rstActHigh = CyFalse;
intfParams.cardDetType = CY_U3P_SIB_DETECT_DAT_3;
intfParams.writeProtEnable = 1;
intfParams.lowVoltage = CyFalse;
intfParams.voltageSwGpio = 0xFF;
intfParams.lvGpioState = CyFalse;
intfParams.useDdr = CyTrue;
intfParams.maxFreq = CY_U3P_SIB_FREQ_52MHZ;
intfParams.cardInitDelay   = 0;
stat = CyU3PSibSetIntfParams (CY_U3P_SIB_PORT_0, &intfParams);
This is returning CY_U3P_ERROR_BAD_ARGUMENT and I don't understand why. Is there something I'm overlooking?
Keerthy
50 solutions authored 25 solutions authored 10 solutions authored
Hi Caleb,
As per your code snippet, you are enabling the write protection on the storage port 0. GPIO used for write protection detection on Storage port 0 is GPIO 43. You need to configure this GPIO as simple GPIO in your firmware. Else the API CyU3PSibSetIntfParams will fail.
Please have a look.
Keerthy
Hi Caleb,
Please have a look.
