CyU3PGpifWriteDataWords/CyU3PGpifReadDataWords using the FX3 as master
We are trying to use the APIs CyU3PGpifWriteDataWords/CyU3PGpifReadDataWords using the FX3 as master and an FPGA as slave. The objective is to be able to write/read registers in the FPGA.
Note that the GPIF is set up for 32-bit synchronous with multiplexed data and address.
A simple example along with a minimal GPIF2 project would be very helpful. None of the examples in SDK 1.2.2 illustrate the use of the two APIs mentioned above.
Any help would be highly appreciated.
