CyU3PDmaMultiChannelGetBuffer returns CY_U3P_ERROR_INVALID_SEQUENCE
bk
5 replies posted 10 sign-ins 5 sign-ins
I'm using Cx3.
My system is "pc - cx3 - isp - sensor" and symptom is camera reboot frequently.
Details are as below:
#1 I used debugprint and found it go to DmaCallback function. in Dmacallback function, CyU3PDmaMultiChannelGetBuffer() returns CY_U3P_ERROR_INVALID_SEQUENCE.
#2 When I plug the cx3 into the main board, the symptom of #1 appears.
#3 When I plug the cx3 into the powered Usb-Hub, there's no problem.
#4 I've used the same F/W on the other Cx3 board(same feature), but there's no issue.
Base code is Cx3UvcAS0260.
How can i fix this problem???
thank you
Hemanth
First like given First question asked 750 replies posted
1. Is the video channel type changed from CY_U3P_DMA_TYPE_MANUAL_MANY_TO_ONE (as in base code) to CY_U3P_DMA_TYPE_AUTO_MANY_TO_ONE?
2. If it is manual, then, can you recheck if Invalid sequence is returned by CyU3PDmaMultiChannelGetBuffer OR CyU3PDmaMultiChannelCommitBuffer?
Hemanth
bk
1. it is CY_U3P_DMA_TYPE_MANUAL_MANY_TO_ONE
2. there was miss typing. CY_U3P_ERROR_INVALID_SEQUENCE is from CyU3PDmaMultiChannelCommitBuffer(). and CyU3PDmaMultiChannelGetBuffer() returns CY_U3P_SUCCESS.
Bk
Hemanth
Hi Bk,
Please check this link Invalid Sequence Error in Multi-Channel Commit Buffer - KBA218830
Hemanth
