xixu_4093676
25 replies posted 10 replies posted 10 questions asked
     Refer to AN75779, I port related code to my project, But in the uvc dma callback function CyFxUvcApplnDmaCallback
    when call CyU3PDmaMultiChannelCommitBuffer, the function return CY_U3P_ERROR_INVALID_SEQUENCE(71).
   For your reference I attach my related code.
Martin.xu
AliAsgar
750 replies posted 50 likes received 500 replies posted
Hi Martin,
Kindly check this KBA for the workaround for the error.
Also it is recommended to not use debug prints inside dma callback functions. As debug prints are slower and in the application like video streaming, dma callback functions are called more frequently. Instead global variables or events can be used to track the failures.
AliAsgar
AliAsgar
Hi Martin,
AliAsgar
