Cx3 - No data received from Toshiba | Different hardware behavior in same firmware
VediGovind
First question asked First reply posted Welcome!
Hi All,
am working on ar1820 sensor  with CX3 controller .
 here taking raw firmware in 10 bits of depth.
it's working fine on some boards exactly out of 10, 5 are working boards and 5 are not working for the boards.
Settings Details:
4 lane - 576Mbpl[MIPI Clock]
24line -  96Mhz[Parallel Clock]
resoution - 4912x3684@9fps.
debugging steps:
1. checked error register on Toshiba
MIPI-CSI Protocol and Physical Layer Errors in CX3... - Infineon Developer Community
it looks Multi-Data Lane Sync Byte Error Count and Unrecoverable Packet Header Error .
thing is Lane sync error happens in lanes 2 and 3 alone.
is there a Lane alignment register present in the Toshiba? or any related solutions?
Thanks for your effort in this matter.
Chaithra_p
50 solutions authored First like given 25 solutions authored
Hello @VediGovind ,
Can you please let us know whether you are using your own custom board? If yes please confirm if MIPI lane routing is as per this KBA ..?
EZ-USB™ CX3 troubleshooting guide - KBA233853
Please confirm if you are using MIPI sensor compliant to MIPI CSI-2  (Version 1.01, Revision 0.04 – 2nd April
2009)
Thanks & regards,
Chaithra
Chaithra_p
Hello @VediGovind ,
2009)
Thanks & regards,
Chaithra
