Hello
Follow the steps introduced in "Steps to Setup up MIPI CSI Camera Solution with CX3 – KBA225748" to create a new CX3 project,According to the results of the article, after the configuration is completed, the new CX3 project should generate files: cyu3mipicsi.c, cycx3_uvcdscr.c, cycx3_uvc.h, cycx3_uvc.c.
But these 4 files were not found after saving the project I created, let alone the generated files: cyu3imagesensor.c, cyu3imagesensor.h.
When configuring, can see the file names: cyu3mipicsi.c, cycx3_uvcdscr.c, cycx3_uvc.h, cycx3_uvc.c. But after the final save, there are no such files in the project manager.
Did I do something wrong during configuration?
Best Regards!
Qimin Liu
USB Superspeed Peripherals
It looks like you havent saved these source files into the project. Each source file needs to be saved by clicking on the save button as shown below:
As mentioned above, this should be done for each source file so that they are added to your project. Please let me know if you see the issue even after trying this suggestion.
Jayakrishna
Jayakrishna
Oh, yes, after saving according to your prompt, all the files can be seen in the project manager.
I just saw the save button in the upper left corner before, so this error occurred.
Thank you for your help.
Best Regards!
Qimin Liu
