Hallo,
      I am using the cypress usb3014 chip for my development. The usb3.0 controler of my PC is  ASMedia USB 3.0 controler,.When i am trying to connect the cypress usb3014 chip with my computer, the driver cann't work.In this case, could Cypress Development board-DVK connect with ASMedia USB 3.0 controler?
 The host side of things should be standard enough that FX3 should be able to work with them. It is a little confusing as to why you're seeing issues.
Please provide more information on your PC environment, Vista/7/XP? 32-bit/64-bit?
What is the error/behavior being seen?
Anand
I'd experienced same case, asmedia driver upgrade will solve the problem.
