Hello!
Currently, I am developing the configuration using the slave SelectMap method by connecting the FX3 with the FPGA.
I can't find an example to create a Slave SelectMap image file.
How should I study to make an image file?
And, what is the correlation between 'GPIF II Designer' and 'EZ USB suite'?
Thank You!
Please refer to AN65974 application note and let me know if it will helpful for interfacing FPGA to FX3 over parallel GPIF interface
As for tools, Is it correct to create a state machine in 'GPIF II Designer' and use it in 'EZ USB suite'?
>> Yes, after building the state machine (designed in GPIF II Designer) a header file is generated which needs to be included in the firmware project and can be built using EZ USB suite
Rashi
