slfifosync example code is running in Manual mode.
Which part of the codes in cyfxslfifosync.c (slfifosync example) represent the "Callback function invoked at end of transaction" by Consumer (Egress) Socket ? illustrated in FX3_PROGRAMMERS_MANUAL page 77.
you need to update your dmaCfg.notification as per 1st replay and then use this if condition, in the same callback function.
Biren
To invoke the callback on the consumer socket we need to register this as an event as I show below.
dmaCfg.notification = CY_U3P_DMA_CB_PROD_EVENT | CY_U3P_DMA_CB_CONS_EVENT;
and then we can catch this event is a respective callback CyFxSlFifoUtoPDmaCallback or CyFxSlFifoPtoUDmaCallback.
Biren
But it is clearly stated in the notes at line 147 and 174 that :
CyFxSlFifoUtoPDmaCallback() : DMA callback function to handle the produce events for U to P transfers.
CyFxSlFifoPtoUDmaCallback() : DMA callback function to handle the produce events for P to U transfers.
Are you saying that i just need to add in another block of
"if (type == CY_U3P_DMA_CB_CONS_EVENT) {...}
to handle "Callback function invoked at end of transaction" by Consumer (Egress) Socket ?
Biren
