TzCh_3504586
5 likes given First like given
I have a RAW20 input while there's no corresponding CyU3PMipicsiDataFormat_t I can use due to CX3 supports MIPI CSI 2 spec 1.01.
If I only want CX3 to pipe my RAW20 data to host, which Data Format should I choose? Will CX3 filter the packets that have DT other than the specified?
Also, does CX3 support Virtual Channel? If I get two Virtual Channel will it able to distinguish them?
Paddy
KandlaguntaR_36
Paddy,
RAW 20 is not supported by CX3.
CX3 does not support virtual channel.
KandlaguntaR_36
Paddy,
Thanks for the response
Paddy
