Ankitvats
I just import the project in "EZ USB Suite" tool and try to build the project in Debug and Release mode.
But the linker script "fx3.ld" is not present in Debug/ Release Folder.
Error :: Cannot open the linker script c:\..\debug\fx3.ld: invalid argument
Environment  variable  set :
FX3_LIB_PATH    =  "${workspace_loc:/${ProjName}/api}"
How to resolve it??
error
 environment variable set
 path and symbole
Rashi_Vatsa
Moderator 500 solutions authored 1000 replies posted 750 replies posted
Please let me know where is the linker script file present for your project.
In the default FX3 projects, the path to linker script file is as in the attached snippetld_file.PNG
You can copy the linker script file to a location and add the path as above in the project settings
Rashi
Rashi_Vatsa
Rashi
Ankitvats
I  copied the linker script file to a location and add the path as above in the project settings.
yes, Now I am able to build the project.
But A note is comming . Is this break the code???
Note: 256 bytes of interrupt vector code have been removed from the image.
Use the "-vectorload yes" option to retain this code.
Rashi_Vatsa
Please refer to readme.txt file in the following location (FX3 SDK Installation path\Cypress\EZ-USB FX3 SDK\1.3\util\elf2img) for more info on vector load parameter
Rashi
Ankitvats
But when we import the project from example in tool then Debug/ Release both have  .mk file (Makefile.mk)
 But in My PROJECT no .mk file is generated  after fx3.ld file cpy on its location.
 Settings are
Rashi_Vatsa
Please let me know which steps are followed for creating the project that you are working on
Please try creating a new template project and copy the source files there and try building it.
File>New>Project>FX3 Project will create a template project for FX3
Rashi
