I just import the project in "EZ USB Suite" tool and try to build the project in Debug and Release mode.
But the linker script "fx3.ld" is not present in Debug/ Release Folder.
Error :: Cannot open the linker script c:\..\debug\fx3.ld: invalid argument
Environment variable set :
FX3_LIB_PATH = "${workspace_loc:/${ProjName}/api}"
How to resolve it??
error
environment variable set
path and symbole
USB Superspeed Peripherals
Please let me know where is the linker script file present for your project.
In the default FX3 projects, the path to linker script file is as in the attached snippet
You can copy the linker script file to a location and add the path as above in the project settings
Rashi
Rashi
I copied the linker script file to a location and add the path as above in the project settings.
yes, Now I am able to build the project.
But A note is comming . Is this break the code???
Note: 256 bytes of interrupt vector code have been removed from the image.
Use the "-vectorload yes" option to retain this code.
Please confirm if the following settings are same as this
Please refer to readme.txt file in the following location (FX3 SDK Installation path\Cypress\EZ-USB FX3 SDK\1.3\util\elf2img) for more info on vector load parameter
Rashi
YES.....
But when we import the project from example in tool then Debug/ Release both have .mk file (Makefile.mk)
But in My PROJECT no .mk file is generated after fx3.ld file cpy on its location.
Settings are
Please let me know which steps are followed for creating the project that you are working on
Please try creating a new template project and copy the source files there and try building it.
File>New>Project>FX3 Project will create a template project for FX3
Rashi
