I read this PDF---"AN84868 Configuring an FPGA over USB Using Cypress EZ-USB FX3.pdf"
and try official example firmware and software.
But, it seem only support Xilinx FPGA's ".bin" file, not intel's ".cof" or ".sof" file.
My hardware is connected as below:
Does anyone know about this application?
Will it possibly works?
Please tell me.
Thanks a lot.
Please refer to this thread Is there any examples of updating Xilinx FPGA bit file through FX3? where the customer was able to program the Cyclone 4 FPGA with AN84868 application note.
Please refer to the FPGA documents to check the pull up resistor values.
The FPGA configuration Utility has an option for all files (*) , so you can try sending the .sof file using the utility
Rashi
Rashi
Rashi
Rashi
