I have a callback registered with CyU3PUsbRegisterSetupCallback and I am not using fast enumeration.
Currently I am using the callback to log setup transactions.
Comparing my log with that from a USB analyzer I can see that I get most SETUP transactions with the exception of SetAddress.
Is it possible for the application to be notified when a SetAddress transaction has occurred?
Hi Levi,
Please refer to register address 0xE0033400 given in FX3 TRM section 10.16.1
Hemanth
SET_ADDRESS is handled by the Hardware and hence application is not notified for the same.
Hemanth
Thanks Hemanth,
Is there any way for the application to read the address after the SET_ADDRESS transaction?
Best,
Levi
Hi Levi,
Hemanth
