Dear ALL,
We received the following question (actually same as the title) from the customer.
Would you please teach us the answer?
We have a question about the SPI Boot Flash for Cypress EZ-USB FX3 CYUSB3014-BZXI.
We are planning to connect Winbond SPI Flash Memory "W25Q16JWSSIM"
to CYUSB3014-BZXI SPI Interface.
(Q1) Is EZ-USB FX3 Flash SPI Command and API compatible with this Flash Memory?
And please confirm if we can use this Flash memory without problem with CYUSB3014-BZXI?
(Q2) Would you teach us if there is/are EZ-USB FX3 documentation and sample program(s),
which covers SPI Flash Memory Access command and API?
16-Nov-2022
Motoo Tanaka
Hi @MotooTanaka ,
Thank you for posting into our community.
(Q1)
W25Q16JWSSIM is not a confirmed Flash but there is the checklist to check if the Flash is available with FX3 device. Please find the checklist in "7.2 Selection of SPI flash".
If there are any mismatch in the commands, you can also change the commands.
AN76405 EZ-USB FX3 Boot Options(English)
AN76405 EZ-USB FX3 Boot Options(Japanese)
(Q2)
Please find the documents above and USBFlashProg of FX3 SDK if needed.
Hi @MotooTanaka ,
(Q1)
(Q2)
Dear TakashiO-san,
Thank you very much for your answers!
Especially I appreciate your providing both English and Japanese version links!
17-Nov-2022
Motoo Tanaka
