After successfully complied the project, EZ USB suite generates .img and .elf files inside the project directory. Is it possible to configure the tool so it can generate .bin file that can be used in a universal chip programmer?
Tony
USB Superspeed Peripherals
Hi Tony,
Currently, we don't have any utilities that can convert a .img/.elf file to a .bin file. You could try giving post build commands in the project properties.
Also could you let us know what is the target for universal chip programmer (I2C EEPROM or SPI flash).
AliAsgar
Hi Tony,
AliAsgar
