CYUSB3KIT-004 EV boardt have lattice crosslink + cypress sx3.
where can find the source of lattice crosslink fpga ?
and the cypress sx3 firmware source code?
I only find EZ-USB™ SX3 Configuration Utility.
Or the source code is not available?
Thnaks
Terry
ispn:42124:1:0
l1:314:1:0
You can find this project in the configuration utility under this path C:\Program Files (x86)\Cypress\EZ-USB SX3 Configuration Utility\templates
As I explain in the previous replay no firmware needs to write for SX3, you can configure using SX3 config utility.
And FPGA bit file you can found in this project but no source code.
Biren
Hello Terry,
CYUSB3KIT-004 is USE SX3 inside and it is a configurable part no need for any source code for this you can configure it using the SX3 config utility.
And bit file for FPGA you can find in respective project templates under SDK install directory.
Biren
Hi biren,
i want use this board to connect our mipi camera.
so i need to change the source of fpga code and sx3 firmware.
I found in AN231295 there is a project : sx3_explorer_kit_uvc_uac_crosslink_slavefifo . It may be the right place .Yet it can not reach by the link. (seet the png i attached)
So did i have the source code? Or it is not possible to get ?
ref AN231295:
Getting started with EZ-USB™ SX3: https://www.infineon.com/dgdl/Infineon-AN231295_Getting_Started_with_EZ-USB_SX3-ApplicationNotes-v03...
Biren
