CYUSB3KIT-003 Driver Issue
Hello Guys,
I just bought the Super fast USB 3.0 kit and installed the EZ USB Suit. I plugged the kit and I see in the Device manager "Cypress FX3 USB StreamerExample Device" but it has the yellow exclamation mark on it. Then I found this message in the properties "The software for this device has been blocked from starting because it is known to have problems with Windows. Contact the hardware vendor for a new driver. (Code 48)". In the Events tab there is line saying "Device USB\VID_04B4&PID_00F1\5&18b5734d&0&6 could not be migrated.".
In the relevant bin directory there is no driver for Windows 10 and I used 8. Could it be the rpoblem? Would you help me please?
Thank you in advance.
Kind regards,
AndDel
Use the Win 10 drivers provided with this KBA and check (http://www.cypress.com/knowledge-base-article/drivers-ez-usb-fx1-fx2lp-and-fx3-kba94413).
------------------------------------------------UPDATE--------------------------------------------------
Please download Fx3 SDK from given  Path and install.
install and bind driver from below path after SDK installation.
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\driver
------------------------------------------------END----------------------------------------------------------
Dear Dhritiman,
Thank you very much indeed. The Win 10 drivers sorted it out. So... I have to slowly learn and it is likely that I will ask more questions. Thanks again!
Kind regards,
AndDel
