I am planning to use CYUSB3065 along with a USB Hub CYUSB3302-68LTXI as in attached ppt.
As I was going through the datasheet of CSI_USB bridge, it mentions that it is compliant to CSI 2 V1.01, however I am pretty sure that using newer camera modules will be CSI2 V1.2.
Is there any cases where this architecture has been tested with CSI2 V1.2 compliant modules?
Is there any other version of bridge from Cypress which can support CSI2 V1.2 compliant devices?
Is there any supported list of Camera image sensors which have previously tested with image sensors and have been tuned properly?
Since this will be a mass production device we will also need future product availability.
Thanks!
USB Superspeed Peripherals
Please find my comments below:
>> CX3 is MIPI CSI-2 compliant (Version 1.01, Revision 0.04 – 2nd April 2009) and is not tested with CSI2 V1.2
>> We do not have MIPI -CSI2 to USB bridge other than CX3
>> We have CX3 examples in the FX3 SDK. These examples uses sensors like OV5640, AS0260.
We have following reference designs
Rashi
Rashi
