I want to use the part CYUSB3065-BZXI in one of the project we are facing, however we need to make a USB link up to 5 meters. May I know which is the maximum USB 3.0 distance you can reach with your device?
Thanks in advance and greetings.
Please let me know if you are referring to 5 meters of USB 3.0 cable length. If yes, please refer to this KBA Maximum Cable Length of USB 3.0 - KBA87012 - Infineon Developer Community
Also, refer to section 12.1 of AN70707 https://www.cypress.com/file/139936/download for SuperSpeed Design Guidelines
