May 22, 2018
11:53 PM
May 22, 2018
11:53 PM
I use the CYUSB3035 chip to set the boot option to 100 (S0 port (eMMC)), which cannot boot the eMMC.When set to 000, can normally burn the firmware and prompt for success.I set the pin of the three boot options to GPIO input, and the corresponding input voltage is set to 100, which can read the input voltage normally and read the correct input voltage 100.Is there any way to know why can't boot correctly?
04:02 AM
May 23, 2018
04:02 AM
Please check if the eMMC was programmed correctly.
May 23, 2018
07:04 PM
May 23, 2018
07:04 PM
The Control Center can be started normally from RAM and can read and write EMMC.
May 24, 2018
08:20 PM
May 24, 2018
08:20 PM
Hi Madhu:
EMMC can read and write.
