I am using CYUSB3014 and the confusion is, It's mentioned in the datasheet that the max SPI flash memory is 32Mbit. Is it possible to change or increase this SPI flash memory capacity. Please help on this.
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
FX3 can support up to 128Mbit flash on SPI. Kindly, refer to the below document for details on the selection of SPI flash. The datasheet mentions a few example flash memory parts that can be used with FX3.
Selection of SPI Flash Compatible with FX3/CX3/FX3S/FX2G2/SD3/SD2 and the Recommended Cypress SPI Fl...
Srinath S
SrinathS_16
Srinath S
