How do I get my FX3 device to generate a compliance pattern?
We have taken care of generating complinace pattern in the SDK library. So if you load any firmware (typically, USBBulkSourceSink example firmware) and do compliance testing, the device will act w.r.t to the host commands.
Hence, you do not need to do any additions/modifications in the firmware to generate compliance pattern.
thank you .. I am using the fx3 test boast with the software, but I am not able to see any compliance pattern coming out.
Can you please provide the failed test report. This will help us to spot the issue and give appropriate suggestions. Also please refer to the following KBA link which has explorer kit compliance test report where you can cross check with your report"FX3 Compliance Tests - KBA209969 ".
Anil Srinivas.
Thank you for your response. Turns out I did not have the correct compliance board. There is only one board that you need to get the FX3 into compliance this is the USB approved USBIF/USB3ET board set.
