CY7C68013-56 pin doesnot contain T0 Aand T1 pin,
is spports timers?
Sananya_14
Hello Geetha,
Yes, for the 56 pin package, it won't support counters since the pins aren't present.
Sananya
Sananya_14
Hello Geetha,
Yes it supports timers. Please refer to chapter 14 in the Technical Reference Manual for more help. http://www.cypress.com/file/126446/download
Sananya
TRM says that,
Each timer/counter can operate either as a timer with a clock rate based on the EZ-USB’s internal clock (CLKOUT) or as an event counter clocked by the T0 pin (Timer 0), T1pin (Timer 1), or the T2 pin (Timer 2).
it means ,
CY7C68013-56 pin supports timer1 and timer2 and doesnot supports counter??
is that correct?
Sananya_14
Hello Geetha,
Sananya
sanm,
thank you...
