The output of CY3065+OV5640 is normal when connected to the computer UVC. After connecting to the Android phone, the UVC device can be recognized, but the camera cannot be opened. Check the log log output of the software and find that: The application is unable to configure the output video parameters. The personal troubleshooting reason may be that the video data is inconsistent. CY3065 outputs YUY2 data format. Does CY3065 support other data formats such as YUV420? Please give directions, thank you!
USB Superspeed Peripherals
Please refer to this thread Solved: CX3 -Android - Cypress Developer Community and let me know if the video streaming works.
Please let me know if the camera is coming up on the host application when the device is plugged in and share the UART debug logs (for device debugging) while streaming when the problem is seen.
Also, let me know if CX3 is programmed using the default OV5640 firmware.
Rashi
