I am trying to integrate camera AR0522 with a Cypress CX3 custom board but failing to configure the MIPI interface correctly.
I noticed that there is existing devkits with camera AR0521 but the EZ-USB FX3 SDK only provide libraries and examples for the cameras AS0260 and OV5640.
Do you know if there is a project example or at least a MIPI configuration example available for the AR0521 (or AR0522) ?
SimonP
USB Superspeed Peripherals
Please find my comments below:
>> Please contact the sensor vendor for the register configuration. Based on the register setting of sensor ( MIPI transmitter), the CX3's MIPI Receiver can be configured with the same settings as sensor.
Please refer to this KBA Steps to Setup up MIPI CSI Camera Solution with CX... - Cypress Developer Community
Rashi
Rashi
