Hello
About CX3 sample FW. Read two project files of cycx3_rgb16_as0260 and cycx3_rgb24_as0260 in Eclipse,
But, I cannot edit the Image Sensor Configuration (xxx.cycx).
・In the cycx3_rgb16_as0260 project, I get an error like the attachment (rgb16AS0260.png).
・In the cycx3_rgb24_as0260 (Cx3Rgb24AS0260.png) project, the "Frame Configuration" screen is locked and cannot be edited.
Q) I am thinking that deleting the existing xxx.cycx and create a new one. but, how can I edit it as it is?
Best Regards
Arai
Hello Arai-san,
As per the "EZ-USB Suite User Guide",
Configuration parameters cannot be modified in pre-defined configuration option, but can be stored as a custom configuration by pressing Save button located at upper right corner of window.
For more information, please look through from "4.4 Using the CSI Configuration Utility" in the EZ-USB Suite User Guide.
Hirotaka Takayama
Hello Arai-san,
Hirotaka Takayama
