I have some problem about YUV upstream and UVC GET request.
The YUV 640x480@30 preview is ok when there is no UVC CONTROL request.
But if there is a UVC GET request on the USB HIGH SPEED connection,
YUV upstream is blocked and 'CyU3PDmaChannelCommitBuffer' throws error.
Is this some kind of bandwidth limitation? or bandwidth reservation for USB CONTROL endpoint?
Any advice and suggestions will be greatly appreciated.
Environment:
Sensor: Samsung M3085
Device : CX3 (512KB), SDK: 1.3.3 or 1.3.4
Preview : AmCap
Thanks in advance.
Please have a look at Section 2.3->IV->second point of FX3_SDK_TroubleShooting_Guide.pdf which is present in the below path of FX3 SDK:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\firmware
Due to this, there is a chance that you get commit buffer failure when you perform control transfer. But video streaming should resume automatically. Can you please confirm the same?
Hemanth
Does the CX3 device enumerate as USB 2.0(High Speed) or 3.0(SuperSpeed)?
Regarding your statement: "But if there is a UVC GET request on the USB HIGH SPEED connection"
- Which control request is being sent when the streaming is happening?
- When you mention USB HIGH SPEED do you mean USB 2.0?
Hemanth
The device was enumerated as USB 2.0 and the control request was UVC Extension unit request.
And the symptom is limited to YUV preview.
Thank you.
Hemanth
I read the SDK TroubleShooting Guide section 2.3 and I think that the DMA suspension of bulk endpoints is the cause of this problem.
Yes, video streaming resumes after DMA blocking resolved.
Again, thank you for you quick support^^
