Minwan
Hi
Yesterday, I uesd CX3 RDK board receive a RAW 8bit MIPI sensor Input, the project build successfully and it enumerated as CX3-UVC. But today ,I  don't change anything in this project ,I find Windows cant recognize the device anymore.
Could you please tell me is there something wrong with my project code or just some hardware issue
Hemanth
First like given First question asked 750 replies posted
Hi Minwan,
Please right click on the project, go to 'Index' and then select 'Freshen all files'
This would remove the errors you see and then build the project.
I assume that your RDK has OV5640 on it.
Hemanth
Hemanth
Please let us know which CX3 RDK you are using?
Try out with a different PC. If it does not work, try to capture UART logs and look for errors.
Hemanth
Minwan
The CX3 RDK i am using is AN90369 .
I build a new project with same configuration and try it again. At the first time, the img file worked and it enumerated as CX3-UVC.  Then I want to try it again to ensure the img file still worked, so I  restart the power supply and reset the hardware, but this time, altough I use the same img file, it  doesn't enumerate as CX3-UVC. It really baffles me.
Thanks for the reply.
Minwan
Hemanth
Hi Minwan,
Can you please program default firmware that is available in FX3 SDK and check if there is any enumeration issue?
Firmware example path: EZ-USB FX3 SDK\1.3\firmware\cx3_examples\cycx3_uvc_ov5640
Also, as I mentioned in my first post, please try with different host PCs and check UART logs for errors.
Hemanth
Minwan
Hi Hemanth,
I program default firmware, but it can't build successfully.
Minwan
Hemanth
Hi Minwan,
Hemanth
