When I was debugging my CX3 UVC project with my own configuration, I encountered the following problem.
Debugging is trapped in the CyCx3UvcAppErrorHandler() API when initializing the MIPI Block module , I want to know if this is a problem with my hardware and I should solve this problem this way, looking forward to your help, thanks a lot.
Yaqi
USB Superspeed Peripherals
Hi Yaqi,
The problem can be caused due to the I2C slave connected externally i.e, from the sensor. Please monitor the I2C bus for the cause of read timeout.
Hi Yaqi,
Can you please let me know what is the 'status' code value?
When I step over status = CyU3PMipicsiInit(); 'status' code value From 0 to 69.
Yaqi
Hi
I found out that when status returns 0x45, the problem is this:
CY_U3P_ERROR_TIMEOUT - If an I2C read/write timeout occurs during the operation.\n
I already know what the problem is, what should I do next?
Yaqi
Are you still there, I already know the problem is this:
How do I solve this problem, can you help me answer it, I'm sorry。
Yaqi
Hi Yaqi,
