Ajitesh_J_S
10 replies posted 5 questions asked 10 sign-ins
I am working on a custom board which uses a Cypress CX3 chip to interface either a Sony IMX219PQ or omnivision OV5647 image sensor  with a computer. For this purpose I need the sensor initialization and resolution configuration register settings. I tried contacting the image sensor vendors, i.e. sony and omnivision for the same. I have attached the response recieved from sony. But they are not providing the values. If anyone else has received these register configuration settings from either sony or omnivision before, can i get help with contacting the right channels for getting the values?
Thank you
Rashi_Vatsa
We would recommend you contact the sensor vendor and ask for the sensor register settings for the particular sensor.
From the attached snippet it seems that your question is been misunderstood. CX3 will send the sensor settings via I2C to the sensor (for initialization) but the register settings/configuration will be provided by sensor vendor
Rashi
Rashi_Vatsa
Rashi
