I am unsure if this is the right place to ask this specific question, but hopefully someone knows the answer!
In Cypress EZ USB Suite's CX3 Configuration project, in the Frame Configuration, we need to set both H and V blanking values. In the example code for OV5640, H blanking is set to 50 for all resolutions and V blanking set to 5. I went through the spec. and ov's source code, and still couldn't figure out how 50 and 5 were calculated!
I am trying to port the example code to support another OV sensor, so without knowing these two values, I couldn't make the project work.
Thanks!
The H-blanking and V-blanking are not rigid and are adjusted to make the other parameters fit.
Please create a Tech Support case so that our engineers will assist you in setting the config for your desiref frame rate and resolution.
-Madhu Sudhan
Hi Madhu,
Thanks for the infor. After contacting a local OVT FAE, I now have a better understand of H/V blanking. Thanks!
Huihai
I 'm having similar issues. If resolved, can you post the FV and LV values here?
