I am working with a sensor at 1280x720@30fps YUV422_8 output, I want to use 24bit-bus to transfer data. But when I set up this project, I found there was data padded to the frame, and I can't preview the frame directly by Amcap. I understand it is because the line size can't be divided by 24bit, then there is data padding. So I want to know how the data is padded to each frame, and how to get rid of the padded data on each frame?
USB Superspeed Peripherals
'm using RGB888 in CyU3PMipicsiCfg_t, so I think there have no padding on every PCLK edge, right?
>> Yes, the padding will be done on every clock edge as 16 bits will be the data received from sensor and rest 8 bits will be padded.
The frame size received currently doesn't seem to be correct and that could be because of line size (not multiple of 24 bits)
Rashi
The padding will be done at every clock cycle i.e. when 16 bits are sampled on GPIF block, 6 bits will be padded on every PCLK edge.
Please let me know if any queries on this
Rashi
Hi Rashi,
I think you may have not get my question.
I am working with a sensor 1280*724@30fps yuv8, and configure CX3 to use 24bit parallel bus to transfer the data to USB.
The original frame size is 1280*724*2=1853440Bytes, but as you can see from above log, the frame zise change to 1859232Bytes, which is (1280+4)*724*2, there is 4 *2Bytes padded to each line I think, is this right? So how is the padding works?
Apologies for the misunderstanding.
>> This is not expected. This could be because the line size (1280*2) is not a multiple of 24 bits (3 bytes)
If YUV (16 bits/pixel) is sent using 24 bit GPIF bus, then 8 bits will be padded on every PCLK edge.
Rashi
Hi Rashi,
I'm using RGB888 in CyU3PMipicsiCfg_t, so I think there have no padding on every PCLK edge, right?
I have printed the frame size in above picture, it semms that there is padding at the end of each line, and how the padding works?
Rashi
Hi Rashi,
Please note that I have used RGB888 in CyU3PMipicsiCfg_t, from KBA224387, I think there will be no padding on every clock edge, please help to confirm!
And I also tested a resolution which is 1920*1280@30fps YUV8 with 24bit bus, of cousre set RGB888 in CyU3PMipicsiCfg_t, whose line size is multiple of 24 bits, and got frame size is 1920*2*1280 bytes but not 1920*3*1280 bytes, it seems there is no padding on every clock edge, so how to explain this?
Hi Rashi,
Hi Rashi,
Could you help to clarify my confusion?Thanks!
