Dear Sirs,
My FX3 is acting as Master, FPGA as slave. I have three input signals from FPGA.(flag_a, flag_b, flag_c)
If I use CPM_CTRL in FX3 state machine, does it compare (flag_a, flag_b, flag_c) ?
(what does "control signals" mean?)
Thanks a lot.
USB Superspeed Peripherals
- fx3
Please refer to the section 4.3.15 of the document gpif2_designer_userguide.pdf to understand more about the action CMP_CTRL. This document comes along with FX3 SDK and can be found in the following location:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\doc\GPIFII_Designer
Regarding your questions,
>> CMP_CTRL can be used to compare flaga/flagb/flagc or a combination of these signals with a comparison value. Please refer to the document mentioned before to understand how this can be done.
The control signals refers to any signal that is described as CTL[x] in the pin description section of FX3 datasheet. The link to the FX3 datasheet is given below:
https://www.cypress.com/file/140296/download
Jayakrishna
Jayakrishna
Dear Jayakrishna Sir,
Thanks a lot for your reply.
I found CTL[x] definition in FX3 datasheet.
If I just want to compare whether {GPIO21(CTL[4]), GPIO23(CTL[6]), GPIO25(CTL[8])}=3'b101 or not,
how should I use and configure "CMP_CTRL" to accomplish this requirement?
Thank you very much
For this requirement, you should unmask CTL[4], CTL[6] and CTL[8]. So, you can use the decimal equivalent of 9'b101010000 which is 336 as unmask value. After this, a comparison value needs to be specified. For your requirement, the comparison value can be set to 5 in decimal. Please try this and let us know the results.
Jayakrishna
