clinton
25 sign-ins 10 replies posted 5 replies posted
HI this is @clinton
I am generating the pwm wave in gpio 50 as a complex mode  with cx3 rdk so i have an issue with this
i want to switch from complex to simple when duty cycle is zero i used overide api with correct parameters
the override function also worked . so problem is when duty cycle is zero I am changing the gpio to simple and set the value to zero but its not work in osciloscope its reflecting with 1 percent duty cycle and same in 100 perecent duty cycle also its showing around 99 percent can any one have any idea??
i am doing somewhere wrong i thinks guide me to reach the endpoint
Best Regards
clinton
Bakal
50 sign-ins 10 solutions authored 25 replies posted
Hello Clinton,
Please share the code or the snippet where you are switching the complex GPIO to simple.
Sakshi Bakal
