lfl_4816136
hello,
I used the GPIF tool to design a state machine, and successfully generated a cyfxgpif2config.h file, but when I added this header file to my project, I got an error
What should I do to add this file to my project correctly?
Hello lfl_4816136,
Please try #include "cyfxgpif2config.h" instead of #include <cyfxgpif2config.h> and try building the project.
Yashwant
YashwantK_46
100 solutions authored 50 solutions authored 50 likes received
Hello lfl_4816136​,
Apologies for the delayed response.
Can you please share a snapshot of the error that you are facing while adding the header file to the eclipse project?
Yashwant
lfl_4816136
Hello lfl_4816136,
Yashwant
Thank you for your help, now the problem is solved
lfl_4816136
I want to drive a set of GPIO and state machine at the same time, so I plan to modify it based on the GpioAPP example
