02:57 AM
Aug 24, 2017
02:57 AM
I have a ZTEX USB-FPGA module 2.14 with onboard FX3.
https://www.ztex.de/firmware-kit/example.e.html
I am following above link of sample example to test.
It works perfectly fine, but I get a message
Info: USB setup finished: high speed
whereas in the example as shown, they get
Info: USB setup finished: super speed
My question is can anyone hint me where to look at, as I am following same steps but not able to
connect at super speed?
11:11 PM
Sep 03, 2017
11:11 PM
Hi!
First, make sure that you have connected the module to USB 3.0 port on your PC.
Could you program FX3 with any of the example projects available in FX3 SDK and check if the device enumerates as SuperSpeed device.
