I am currently designing and reviewing with CYUSB 3014
Application note AN 70707
001-86523_AN 70707_EZ-SB_R_FX 3 _TM_FX 3 S _ TM_ Hardware_Design_ Guidelines _ and _ Schematic_Checklist_Japanese.pdf
Data sheet
CYUSB 3014 (EN) _ 001 - 79232. Pdf
, The following difference is found in the power domain diagram of EZ - USB FX 3
· U3TXVDDQ Pin does not have corresponding PIN in CYUSB 3014 data sheet
※ 2 PIN exists for U3RXVDDQ. (A 2 / B 5)
· Does U3VSS being pull-down processed correspond to the data sheet U3VSSQ of CYUSB 3014?
For the difference between the two points, what kind of terminal processing should we do if it is replaced by 4P in Figure 1 of application note AN 70707?
We confirmed the PDF of the Chinese version and confirmed that the above has been corrected, so this reply is unnecessary.
