Mar 04, 2018
11:17 PM
Mar 04, 2018
11:17 PM
Hi, I'm developing UVC sensor board using FX3. My goal is to achieve 1080p 60Hz throughput, but I've found what I got is just around 1080p 20Hz at best. If I increase fps, video is crashed. I'm following the design of AN75779. I heard that if you want very high throughput use slave fifo architecture which is probably need glue fpga logic(AN65974). I already made my board. Is there no way to get more bandwidth in AN75779, and without fpga?
02:13 AM
Mar 05, 2018
02:13 AM
1. You can try increasing the DMA buffer sizes.(eg: buffer size = 48*1023 and buffer count = 2)
2. Always use max. payload size a multiple of endpoint size. Host expects data in sizes of payload.
