Hello. How can I change the byte order from little endian (default in AN75779) to big-endian.
what/where should I change in uvc and descriptor file to support it for big-endian order.
Please suggest~
Regards.
USB Superspeed Peripherals
yes, we can't manage data orders using GPIF if it is just an 8-bit data bus, we can change the endianness if we have more than 8-bit data.
Biren
Is your data bus from the image sensor is more than 8 bits?
Biren
I am not getting how you multiplex 16-bit over 8-bit can you explain it or send GPIF configuration?
Biren
@Biren_R Hello.
This is similar to the AM75779 mentioned the camera sensor interface where the bus is of 8-bit and pixel data from sensor is 2 byte (16-bit) and receiving over 8-bit bus multiplexer. So, the one data line (ex. D0) receiving 2 byte data as 1byte - 1byte order.
Hope you understand!
Regards.
In this case, FX3 can't reorder data with GPIF configuration so i suggest you can reorder this before FX3 or you can reorder at the application side in the host.
Biren
It is useful when you have more than an 8-bit data bus, in your case data bus is 8-bit only.
Biren
Biren
@Biren_R Hello.
Thanks for your comment. I confused, you said "we can change the endianness we have more than 16-bit data.", or it should be more than 8bit?
Please clear.
Sorry, It is a mistake more than 8-Bit data is currect.
Biren
@Biren_R Thank you for clearing this.
means, the FX3 endianness is depends on the 'bit-bus' if its more than '8bit data bus', doesn't matter how the data (data order) is coming on the bus.
Regards.
endianness itself applies only when data is more than 8 bits, in your case you have 16-bit but it receives as 2 8-bit data. if data bus more than 8-bit then you can select endianness from the GPIF tool.
Biren
