USB superspeed peripherals
 I used AN75779(How to Implement an Image Sensor Interface with EZ-USB® FX3™ in a USB) Source.
CyU3PDmaMultiChannelSetWrapUp() function is succeed. But Sometimes CyFxUvcApplnDmaCallback() isn't called.
So losing about 2 frame per second, 28 frame appears.
Please help me.
 please look for the updates under #define check_last_buffer. See if this helps.
Karnik
Hi shah
I had the same error in my firmware"AN75779 CyU3PDmaMultiChannelSetWrapUp () Problem" error code 71.
But i can't find "# define check_last_buffer". could you tell me where i can find it.
Thanks!
