I want to use FX3 to do link up with USB 3.0 compatible Pen drive, will be using FPGA on the other side of the FX3.
but I just want to use USB PHY layer data out of FX3 and to give the same to FPGA, as all USB protocol-specific things are inside FPGA except for USB 3.0 PHY Layer.
So does FX3 have any configuration just to get only USB PHY (transceiver data ) out of the chip and the same be given to FPGA or Data that is just coming from AN86947(inside FX3) can be given to FPGA via any port?
Your comments on this will be really helpful for us.
-Yashu
Hi Yashu,
There's no provision to use only the USB PHY layer of FX3 alone and there's no configuration available for the same.
Yashwant
Hi Yashu,
Yashwant
