Dear cypress team,
i need to use GPIF II designer with 24 bit data bus. but 24 bit option is not available in designer tool . can you explain why it is not available . and please give a suggestion if it is possible to use 24 bit data bus width after the config file is generated. .
thanks and regards,
Rakesh
Hi Rakesh,
Save the project as editable. Open the editable project in GPIF II Designer, you should be able to change the data bus width to 24 bits.
AliAsgar
Hi Rakesh,
AliAsgar
Hi AliAsgar,
Thanks for your reply,
I have modified Data bus width to 24bit and generated config file in that config file i am unable understand the register values.is there any any document available to understand this register tables. if not please elaborate us to understand this values.
Thanks and regards,
Rakesh
Please refer to FX3 TRM page no. 308 onwards on details on the GPIF register names and their contents. We cannot share any other details apart from the ones mentioned in the TRM.
AliAsgar
