Can you tell me if there is a driver WIN10 for device cy7c68001
Alain
You can download it here:
http://www.cypress.com/knowledge-base-article/drivers-ez-usb-fx1-and-fx2lp-kba94413
------------------------------------------------UPDATE--------------------------------------------------
Please download Fx3 SDK from given Path and install.
install and bind driver from below path after SDK installation.
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\drive
------------------------------------------------END--------------------------------------------------
- Madhu Sudhan
- Madhu Sudhan
The link above is not working, anyone have driver to CY7C68001 for Win10
Could you please explain the issue in a more detailed way? Did you try binding with the driver manually?
Is there an error shown while binding? Is the device enumerating? How is it visible on Device Manager?
