USB low-full-high speed peripherals
 the board connect to the power that pc found che chip very slow  , about 3 mins
Can you please detail your problem. Sorry that I did not understand your problem well.
Gayathri
I'm sorry ...
after power-on PC recognize usb very slow.
about 3 minutes.
Can you please take a trace of the USB traffic using any of the USB bus analyzers (like CATC/ Ellysis, etc). Attach the same here so that we can analyze.
Gayathri
Thank for your reply!
If I have a USB bus analyzers ,I think I needn't  your help.
connect to the PC usb port ,computer found the device about 3 minutes later.
some quick,some slow,....
Did you run eye diagram to see how good the signal quality of the USB interface of your board is??
Do you have a FX2LP DVK? Did you try connecting one to your PC to see if it is not a issue with your PC??
Did you try it in other PCs to isolate whether it is a PC issue??
Anand
