I was reading a discussion about setting the serial number "FX3 Serial number ". What I read was trying to use a SerialNumberGenerate.exe . So I tried to run the executable with my hex file output (probably wrong). The output I received is below.
C:\Cypress\SerialNumberGenerate>SerialNumberGenerate 7 Project1.hex
Exception. Please check the file path... Press Any Key to Exit...
C:\Cypress\SerialNumberGenerate>SerialNumberGenerate 7 .\Project1.hex
Any ideas what I am doing wrong ?
- SerialNumberGenerate in FX3 Serial number was a test application for reference. It was customized for the user who asked for a serial number starting with 'CA'. But, it can be modified if you wanted to have a different character string.
- The application was meant for generating IMG files and not HEX files.
- The application expects 3 arguments which is different from your implementation. This is the reason for the exception. Please read through the Readme.txt file attached with the application.
Srinath S
Srinath S
