gean_3054931
how to build release version in keil2 in fx2lp?
let me know the procedure for this.
thank you.
SrinathS_16
250 solutions authored 100 solutions authored 100 likes received
Hello Geethanjali,
The 'Options for Target <TargetName>' dialog box contains a tab named 'Debug' for debugging the firmware code and adding breakpoints. The 'Output' tab in the same dialog box defines the path and name of the executable HEX file that is generated.
Srinath S
SrinathS_16
Hello Geethanjali,
Srinath S
