dasu_2655076
Hi Cypress,
for production, we need to program the EEPROM 24LC128 for Cy7c68013, it is easier to program the chip with a standalone programmer. but the programmer only loads HEX file.
the HEX file compiled from uvision can't be used for this purpose.
what we can do is use HEX file, convert to iic format, then load to 24lc128 on a developing board. then use the programmer to copy the image to a file. then burn this file to the EEPROM. is there a way to generate a HEX file can be burned in the EEPROM directly.
David Sun
Sananya_14
Hello David,
Please follow up on your other similar thread-IIC work and HEX file can't program EEPROM
Sananya
Sananya_14
Hello David,
Sananya
