Dear sir/mam,
there is no utility given in the cyusb for linux to download the binary firmware file to RAM of the FX2LP.
need help any idea please let me know,
rohaan
Check this http://www.cypress.com/?rID=57990
Dear sir,
Thanks for the reply
I am using cyusb linux as terminal utility and i didnt found any code or utility which can download the binary firmware file .bix
regards
rohan
In the linux SDK, you can find fx2_download.cpp file in the path: cyusb_linux_1.0.4\gui_src
There functions for RAM load and EEPROM load for FX2LP.
Dear sir,
i am using cyusb_linux_1.0.3 thats what i got in the package FX3_SDK_B125. but i didnt found any of the code which will Download binary file(.bix firmware) to RAM. can you please upload this source file for me please, i willl be greatful if you can
Thanks and Regards
rohaan
Hi rohan,
.bix is an old format. We've been using .hex for quite some time now.
why would you still want to use .bix? please let us know.
Anand
Dear sir,
@NKL Thanks sir i will look in to download.cpp and thanks for the help i will go throught it. Thanks again.
@assi sir i know everybody uses the .hex almost evrybody but i have ready firmware with .bix format and now its hard to get this in .hex Your very much right but i have .bix firmware only
Thanks for all the help.
I believe you can just rename .bix to .hex
The data will remain same. You can confirm that by comparing the files.
.bix is binary data i.e. the data at a particular offset is the data to be written to the RAM.
.hex is the intel hex file format representation of the same (has : , address , checksum overhead). .hex specific utility isn't supposed to work for .bix. Please check your firmware download sequence and let me know what happens.
Anand
