gean_3054931
I have implemented vendor command in order to control the data from the fx2lp to usb.
I have interfaced image sensor with fx2lp in slavefifo configuration.please find the below code.
#define Data_control    0xb2
#define no_data_control     0xb3
BOOL DR_VendorCmnd( void )
  switch(SETUPDAT[1])
  case Data_control:
  break;
  case no_data_control:
  break;
  return(FALSE);
So,depending on vendor command recieved by the host,fx2lp needs to control the data flow.
if data_control command recieved,i have to send data from fx2lp to usb.
if no_data_control command recieved,i dont want to send data from fx2lp to usb.is there any logic to implements this?
regards,
geetha.
Sananya_14
Hello Geetha,
Based on my understanding, you can initialize the FIFO in Auto mode in TD_Init() and switch to manual mode in the no_data_control command and skip the packets based on your requirement. Please follow up onfx2lp in vendor commands.
Sananya
Sananya_14
Hello Geetha,
Sananya
